- Joined
- Feb 1, 2017
- Messages
- 6
- Reactions
- 3
- Age
- 75
After I restored the factory defaults to my Mavic Pro it will no longer connect to the computer. When I plug it back in with the same cable I have been using for weeks, it cycles on and off every second and won't connect to the computer. I have changed the cable to a new one. I have switched to a fully charged battery. I have removed the SD card. I have turned the computer and the drone on and off several times. And even worse, the drone will not connect with the remote control anymore. DJI Assistant 2 says the remote has version 01.03.0700 and that's what I wanted to load into my drone. But first I ran the factory defaults and had DJI Assistant 2 load them successfully into the drone but then it immediately started cycling on and off and could no longer be reached through the computer or the remote. I want to load the same release 01.03.0700 into my drone. Please help. Better than any description is my 10 second video "https//youtu.be/LKq25x_JFGA"
