Here is my advice before you fly your first Litchi waypoint mission. At first, I would use Litchi in FPV mode, so you can get used to where everything is on the screen in real life. After a few flights in FPV, then I would implement a simple 3 WP mission. If that goes according to plan, then start getting more elaborate with your missions. What I have found is that Litchi is only as good as you program it, and then reality gets involved.
On more complex missions, its a good idea to prefly the mission in FPV, make sure there are no obstacles in your intended flight path. Then once you have an idea of the best altitude, and have your waypoints set up, you can play the mission, but keep your finger on the pause button!
