1TB Sandisk Extreme Pro for Mavic Classic?
leebroath
Scotland
Just out of curiosity, can I use the 1TB Sandisk Extreme Pro in the Classic?
I‘m aware of only using smaller cards if the drone was lost, but just asking for info :)
Would it work all ok,
These cards are falling quite a bit in price now since a few months back
As per below:
512 is the maximum recommended per specs.
I’m not able to answer since I’ve not tried one.
Look under the storage section.
Reactions: leebroath
Only way to know for sure is to try it and test it. It's not listed, and it would be complete overkill, like putting jet fuel in a VW! You'll never need more than a 32GB card in a single flight, even with continuous video. Better to have multiple 32GB cards and change cards every time you swap batteries.
It will format your card at 512.
So you are wasting you money. I use 128gb in my drone and 256 in my controllers.
I use the practice of changing battery changing card at he same time. 128gb are only around $15 so I keep about a half dozen around. For the price of a 1tb you could get 9 128gb cards. Remember cards fail so dont put all your eggs in one card 😂. If you buy smaller card you would have more.
No . these 1tb sd cards do not work .I have tried . Can this be solved with a firmware up grade ?
JReynolds078
