Any reason not to hand catch?
  • Thread starter Deleted member 65595
  • Start date
D
Guest
Yesterday I was forced to both start the Mavic from my hands, as well as catch it when it returned. The ground was uneven and rocky. So I wonder, is there any reason not to do this all the time? Seemed safe to me
The only reason not to do it is it's not as safe as landing on the ground.
This video shows a few ways to hand catch as safely as possible:
Practiced hand catching and takeoffs in my yard then went out in the boat and it wasn’t a problem - i wasn’t moving either - worked great - turned the drone around so it was facing away, hit land on the controller, stuck out my hand and hand caught it - I made sure my index finger was in around the gimbal and I still have all my fingers
As far as landing I just put it above eye level and in a hover sideways and watching what I am doing reach up and get it between my thumb and other fingers. Been like that since the mavics came out and caught the Phantoms by the leg.
Taking off I have only done to see if I could but if I had to I know I could. You just got to have your attention on what your doing and nothing else. Find what’s comfortable to you and after awhile it’s second nature.
I am attached to my Fingers :cool:
Reactions: Kelley
We hand catch almost every single flight and hand launch about 1/3 of the time.
If practiced and done correctly there's very little danger and the props don't remove your fingers... although in cold weather it may feel like they do . . .
Hadn’t thought about compass issues. Have always heard not to do compass cals with a watch or anything metal on
So wonder if having one on would/could mess it up hand launching.
Just a thought.
So wonder if having one one would/could mess it up hand launching.
Just a thought.
Have thought the same myself. It seems that brass and stainless steel compass housings don’t Cause a problem. Non ferrous metals don‘t influence the operation of Mavic or phantom compass from what I have seen either based on my very basic testing (looking for an observable change in mod value when bringing various non-ferrous metal objects in close proximity to the magnetometer) and direct experience.
Just a thought.
Never has for me. Maybe I've just been VERY lucky :)
Reactions: dirkclod
Some vendor in the Spark group has developed a hand held landing pad that you can velcro all your equipment to and, if compass calibration is needed, can remain attached to the pad and just rotate the disk as required for calibration
The same device is on this blog by the inventor @Phantomrain.org
Wonder if you get a good calibration without removing the other components, extra batteries, etc.? If not, I’d do the “drone dance” with my bird handheld.
Reactions: pmshop
Yes, it's possible to do it every flight...I do it all the time, to take off or landing , because I fly mostly in mountains or accidented terrains...
Just be careful about not be hitten by the props when catching it..grab it from under: make it coming down slowly above your hand and slow down the power..
Maybe the drone will want to rise up a little bit above your hand, juste keep the throttle stick back, it will go down again after a 30cm rise...
I didn't notice any issue doing that since I got m'y mavic pro..
When Hand Landing my Mavic Pro Platinum I do the following:
Establish a nice controlled approach to my location. When the aircraft is about 5 feet away I hover, rotate the aircraft "Tail In" (facing away from me) and come in slowly at around eye level. When it's 2' away I let it hover in place and stabilize. I then ease in from underneath but off to the side (belly sensors) and firmly grasp it in the middle and quickly rotate the aircraft upside down. This immediately shuts the motors OFF and you can carry on with your next step (battery change, packing up for the day etc . . .)
In regards to PhantomRainSuit Lunar Landing Pad.... Mine should arrive ANY day now :) Can't wait get it into use.
Reactions: Mavic Pro Platinum
deepdark
