Camera and gimbal issues while recording
Dabernie
Every single time I record a video, the recording is forcefully ended and the gimbal points the camera up to the sky. I tried upgrading and downgrading the firmware. Is this a hardware issue?
Here's a clip of the issue:
2017_03_09_16_28_27.mp4
Mine did that for the first time today. I wasn't recording video at the time and just flying around in the parking lot at work. I just landed and did a gimbal calibration and several flights later it hasn't done it again. On a side note you could get rid of some of the glare in your video if you are comfortable removing the gimbal cover (that is if you had it on in that video).
I calibrated the gimbal today, then decided to record with the props off and I could see the gimbal spasm upward as the recording forcefully stopped. It still happens on every single recording without fail, my record time being 5 minutes long at most, and 12 seconds for the fastest failure. I do have the plastic dome on, I should probably take it off haha.
Give it a shot without the gimbal cover to see if it is causing some sort of interference. If not best of luck brother. I haven't had to deal with DJI support but the thought scares me on wait times.
I flew by the house today and the camera would vibrate like crazy. I calibrated the gimbal and centered it but to no avail. Never crashed it at all. What could be the problem?
No idea. I replaced my Mavic altogether, seems like some are simply defective.
Flying with the dome on will overheat your drone !
tflys78
