- Joined
- Oct 12, 2016
- Messages
- 28,329
- Reactions
- 31,189
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
A visual presentation showing the actual flight data is indeed quite useful in this type of evaluation. Not everyone is able to look at CSV data and visualize what is happening to the drone.only referring to the PhantomHelp logviewer presentation
If you look at the raw data, you can see the aircraft begins the unusual yaw right after (nearly at the same instant) the OP abruptly moves the elevator to the full up position. It could be a coincidence, but it seems more likely to be the cause than a bird strike or debris dropping into the motor at that very same time.the drone also yaws even though no yaw command is given with the left stick... it's in neutral position all the time
