Cincinnati Area
Hello from the Crossroads of America Deuces.
Looking to buy a DJI once I figure out what model I should start with.
There's plenty to choose from.
You need to take the TRUST test and keep a copy with you when you fly, whatever that may be.
It's a free, no fail test that's easy to take about the basics of flying a drone.
Depending on which model you choose, it may need to be registered with the FAA.
Good luck and have fun shopping.
Welcome to the Forum. :cool:
Welcome to the forum from the beautiful woods of Maine!
Buying a drone is like buying a new car, it all depends on: a) How much you want to spend; b) What you’re going to use it for and c) What options you would like.
Check YouTube for variations of drones and options then search this forum for answers to questions you have, there’s many knowledgeable members willing to help you decide.
new to hobby. In fact just have a toy drone for now. Looking to buy a DJI once I figure out what model I should start with.
Once you pick your drone, as a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Ohio, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
Hello from Minnesota! For your first drone I suggest you look at the Mini 2 fly more combo from DJI or a Mini 3 refurb with the RC controller. It’ll be a low cost of entry to get into the drone world and if you decide you enjoy it then look at the air 3 or the Mavic 3 Classic. I suggest a Mini series because they cost less than the above mentioned and if you happen to crash it you won’t be out too much money.
Which brings me to the DJI insurance. Get it for at least a year in case you crash and DJi will send you a new one at a reasonable discount. You very well may be thinking ability getting a high end drone right away but I advise not to as you don’t want to crash an expensive drone right as you get into the hobby. Flying the Mini 2 or mini 3 without obstacle avoidance will teach you to respect and be mindful of your surroundings but if money isn’t an object grab the Mini 3 pro with the RC and learn to fly on that model which has OA.
You can always buy the fly more combo later on if you decide this is something g you want to continue.
Welcome to the forum! :)
DrDew
