The security app?Maybe SecNeo was the cause? ... Just a thought ...
The whole encryption stuff in which GO4 is being enclosed.The security app?
Makes sense, but wouldn't that be an App update rather than a FW update?The whole encryption stuff in which GO4 is being enclosed.
As you are using GO4 the code has to be decrypted before it can be used.
This crypto process eats up more CPU power -> more heat is being produced ...
Yes, i think also, but the hell knows what DJI has built into the firmware which needs to be fixed aside the GO and GO4 apps.but wouldn't that be an App update rather than a FW update?
Well it looks like DJI has identified the CS overheating issue and knows the cause(s). With that said, I would recommend updating FW as soon as its available.
Not sure how well this works...mine SN came back with this:My CS Ultra which has been getting hot but has not had any screen issues has a build date of 15/10/17, I wonder if the build date has any relevance to the screen failures.
You can check yours , thanks to Msinger
DJI SERIAL DECODER
No zeros in my SN. I'm retrieving my SN from the CSBy the way in the serial number the "o" are all zeros
Wow that's a totally different # than what comes from the CS screenI just took it from under the battery underneath the QR sticker
Same here ...I just took it from under the battery underneath the QR sticker
wELL THAT # WORKED:I just took it from under the battery underneath the QR sticker
