DJI Assistant 2
fredgsy
Morning. I have just done a firmware update on the Mavic. Just also checked to see if everything was OK with the DJI Assistant 2 on the iMac. It tells me it cannot find the firmware and would l like to re set to factory settings. I am wondering if there is a new version somewhere of the Assistant 2 and if so, where can it be downloaded. Not had this issue before. Many thanks.
I had the same problem. I did an uninstall of the DJI Assistant 2 software. I then downloaded the latest DJI Assistant 2 software from the DJI web site and installed it. Everything works fine now!
Reactions: ksmusa and fredgsy
The old version on dji V1.1.2-2 assistant no longer shows what version of software you have it has been made invisible. The new version does though so I run both one to mod with one to check with
Reactions: fredgsy
Thanks guys - new version now downloaded and working. Much appreciated for your kind replies.
bullet_magnet
