Dji mavic mini does not turn on anymore
Danyuc
Texas City, TX, USA
Hello,
I have a problem with my mavic mini.
Indeed during the reassembly of my Drone (to change the pod) I tried to start it but it does not want ....
When I press the start button, the battery lights up but then when I press the second button to start it, it turns off as if it did not detect that I wanted to turn it on.
I tried to connect the charger on the Drone to see if it recharged the battery and it charges the battery correctly.
Thanks in advance
What is "the pod"?
If the problem has arisen following a DIY rebuild of the drone then I would suspect one or more of the following.
1) You damaged something in the process of dismantling and reassembling the drone. This is quite easy to do especially the way some things are glued down.
2) You forgot to connect something.
3) The replacement part is defective.
Just checking when you press the battery button for the second time you’re pressing and holding it pressed until the drone starts up?
Va1entin
