Flying while sitting in my car
SteveCA
My buddy and I were out flying yesterday in cold and very windy conditions. He got too cold so I suggested that we fly from inside our car. We kept a very close eye on the controller and Video signal strength. It worked just fine and we stayed warm. We were careful to keep the Mavic in front of us and never had less than full bars of signal strength. This is going to be very helpful for those kind of days!
Yes. That's what I did while testing my skills in flying POI manually while sitting comfortably in the back seat of my tahoe with the a/c on full blast (it was on a warm day). :)
Reactions: SteveCA
Nice to know as we're due some cold weather soon here in the UK
This is with Mavic yesterday
Phantom 3 about 5000 feet
Both sat in truck.
Through windscreen there is precious little difference and you can see the screen much better too.
Reactions: Fplvert
I wouldn't expect the range to be the same as essentially you're inside a Faraday cage with lots of shielding from radio signals. But just like a mobile phone working inside your car, it will still work. Driving and flying simultaneously though is not recommended ;-)
Thats what i figured too but whatabout the tracking features? I mean having it track u while ur riding with controller mounted on the bars is the way u do it so...
How does it deal with your home point not being set on gps? Like if it tried to return to home where would it go
It would return to wherever you had your home point set...unless you change the home point to your new location.
Can u change ur homepoint on the fly like that when the drone is out in the air
A Faraday cage with a hole ANYWHERE on it will not stop any wavelength that is smaller than the hole.* A 2GHz signal needs a hole that is 13cm. At 5GHz you need an even smaller hole. Luckily a car has quite a lot of holes bigger than that.
* Physical analogy: a concrete barrier around a portion of a pond. If no holes, water inside barrier doesn't wave like the water outside. Small holes allow small ripples. Big holes allow big waves. Almost entirely independent of direction of waves.
Reactions: HeavensAbove
Thanks for the lesson, but I did electrical and electronic engineering to degree level ;-)
What you say is entirely correct, which is why I agreed it would work. If the car didn't have windows however....
Excellent information for old guys like ME!!
Excellent Information
Reactions: SteveCA
Ive flown from inside a house looking out a big picture window. Just keep a close eye on the signal strength meters and keep in in line of sight
If the car didn't have windows? It wouldn't be a car.
volpe
