Hello From Arkansastan!
Welcome to the forum! :)
Hello from the Crossroads of America propflux01.
propflux01 ..."Hello From Arkansastan!"
Love it. ❤️
If you haven't done it yet, you need to register the Air 3 with the FAA.
Also, you need to take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
If you don't have the B4UFLY app, it's good to have when flying around Arkansastan airspace.
Good luck with your future flights and welcome to the Forum. :cool:
Just bought an Air3
even though you have been flying Homebuilts, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). The Air 3 weighs more than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. This also applies to all your "heavy" homebuilt drones.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Arkansas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
davidt2
