Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean.
Welcome again!
Welcome again!
Thank You!Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean.
Welcome again!
Hello! Thank You so much for all of the information and the link to the manual!!Welcome from the Hampton Roads area of Virginia. I too am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). Open the front legs, open the back legs of your drone, then remove the Gimbal Cover.
Place the drone down while it finishes its self-test (collecting satellites, etc…).
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby;" also read over the user's manual… the link is below in case you did not get one…
Happy Droning
Thank you!!Jess: Welcome to the forum from Chicago the Windy City.
