Hello from Fredericksburg, VA
Hello, new here from Fredericksburg, VA. Running a mini 2 in the area.
Welcome to the forum from 8200ft in the Colorado Rocky Mountains! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Even in Virginia, there are a couple of Legal Things you may need to do… Since you did not say if you are also new to Droning…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in Vurgubua, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
volidas
