Hello from Fredericksburg, VA
Welcome to the forums - great place to get tips and answers to your questions. Also, the search function if an excellent place to search for the many questions a new member will have.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Welcome to Mavic Pilots :) Enjoy the forum!Thumbswayup
Welcome to this forum. If you can’t find the answer in a thread search, don’t hesitate to ask away. The folks here are very helpful and knowledgeable. On a side note I’m very familiar with Fredericksburg, Va. I graduated from(at the time, known as) Mary Washington College, now UMW. I lived in Fredericksburg from 86’-92. Altman’s barbecues, the Parthenon , and Sammy T’s were my go to’s to eat.
Blue Skies from SoCal.
P.s Battlefield restaurant for breakfast ?
Hello, fellow Air heads -- looking forward to learning from you all and offering up my own lessons on what not to do with your Mavic Air. I'll start with that profile tracking feature. You know when the YouTube videos caution us that there are no side sensors? Lamp posts are an excellent reminder!
Welcome from New Zealand. Airhead, never been called that in this context ?? happy flying.
Welcome to Mavic Pilots from Dayton Ohio! Enjoy your new Mavic Air, Fly safe and have fun!
I’m in Fredericksburg
Reactions: Steel63
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Even in virginia, there are a couple of Legal Things you may need to do… And since I do not know if you've done them, I'll remind you.
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. But I think your Mavic Air is required to be registered….
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in Virginia, there are specific laws and rules for you to follow, please check to ensure these are current. I do not believe there is any laws about flying into lamp posts….
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: Steel63
PilotOne
