Hello from Metro Detroit, Michigan - USA
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
You have already been given the advice by MA2 317 to get your TRUST Certificate and recommednded registering it, BUT, I'll say it again. There are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…) FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Link to the FAADroneZone (Optional for Drones under 250-Grams…) FAADroneZone
Now for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini SE - Download Center - DJI
Happy and Safe Droning…
That was a very well put together informative guide for all of our new community members. On behalf of the community, Thank you for your Service, Time and Consideration
Welcome to the forum! :)
Thanks for the information and tips LoudThunder! I have my TRUST certificate and am half way through my Part 107 training (both through Pilot Institute) and have also registered my drone With the FAA, Plan on upgrading to a Mavic later this summer or fall.
Hello and Happy 4th of July!
New to the forum and new to drones. Been wanting to get one for a while and finally did it a few weeks ago. Figured I better learn to crawl first so I am starting out with a DJI Mini SE before graduating to a more robust unit.
Been lurking here for a while and learned so much. I don't know if I will be able to contribute much at first, but certainly do appreciate all the great people willing to share their knowledge. Helped me make more informed decisions concerning equipment and accessories.
Mike
Welcome to the forum FireMike I to live in metro Detroit (Westland) .just put it out there, a lot of great people can be found here. Stay and fly safe.
Mike
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Mike
Welcome
