Hello from San Francisco
Hello from the Crossroads of America dennisj.
The mini 3 doesn't need to be registered with the FAA, unless you add accessories to it that may push it past 249 grams.
It's only five bucks and the numbers look cool.
You should take the TRUST test and keep a copy with you when you fly.
Good luck, have fun and welcome to the Forum. :cool:
Thanks! Already have a TRUST card.
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
New owner of a mini3 with a few dozen flights under my belt,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. You might find some new friends to fly with…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Now that yu have some flight time under your belt, be careful as you get more proficient and confident, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Keith J
