Welcome from the Hampton Roads area of Virginia, USA. I am a
Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
If you are in the U.S.A. there are a couple of Legal Things you need to doā¦ Register your Drone, that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute We Site (FREEā¦) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
If you live in another country and are flying there, be sure you are following all of the laws and rules applicable to you.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its ownā¦). On the Drone, open the front legs, then open the back legs, then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the cover so it's more noticeable and I do not forget to remove itā¦
Turn on the drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first timeā¦
Place the drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etcā¦).
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery point and when it engages Return to Home and lands in the pond or in a tree; it will be all on youā¦
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro. You will also find the 74-page
Mini 3 Pro's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
After you read the Manual, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary momentā¦"
DJI Mini 3 Pro - Downloads - DJI
Happy and Safe Droningā¦
