Hey from the UK!
United Kingdom
Hey Everyone
Newbie to the drone scene wanted one for years and finally pulled the pin, looking forward to exploring & making memories using the DJI mini 3 pro. Joined this forum as it seemed really friendly/supportive and informative. Happy to be here and look forward to hearing about your experiences and hopefully be able to learn a few things along the way.
Happy Flying!
Hello and welcome! Always good to see another UK Mini owner. :)
If you've not done so already, read the UK drone regulations and get your CAA Operator ID (you don't need a Flyer ID for a Mini): The Drone and Model Aircraft Code | UK Civil Aviation Authority so you're flying legally. Or consider joining an organisation like BMFA or FPVUK to get your Operator ID and insurance through them (gives a few other benefits but costs more than just the bare CAA registration). The registration test is multiple choice and you can search for the answers in a different browser window on the regulations page if you're not sure.
It's worth taking a look at sites such as Where To Fly Your Drone in the UK to see if there are any restricted areas near where you plan to fly too.
Welcome to the forum! :)
Hey! & Thanks for the links, i have watched lots of youtube/dji videos and just going through the DJI training beginners guide. hopefully that will set me up for a good start!
Hey!
thanks for the above information. i have done a lot of research into what you have pointed out and opted to get both flyer ID & Operator ID just incase which i did this morning. i was going to ask the question eventually regarding insurance but didn't want to spam the forum to soon. i will check out the information you have provided about insurance as i just want to get everything sorted so that i can potentially be over covered for flying in the UK. i have come across that page in my research & did download an App called Drone Assist which seemed to have a lot of good information about flight restrictions based on location while using the app, not sure if anyone has used it or how reliable it is.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
brokerman
