Hi from Scotland.
First real drone. Mini 2 SE. Bought this as a starter. I really like it. Nice forum BTW looks helpful.
You're Darn Tootin' this is a "nice forum" ;)
I challenge you to name any other forum where they send you a link to the local laws you must fly by in Scotland and a link all the downloads the manufacturer puts on your specific drone, the Mini 2 SE, including the User Manual… We Aim to please… 😁
There is also a specific Mini 2 SE Sub-Forum where you can get lots of advice and news… If you have questions that are general in nature, post them in the General Discussions where the most of us "hang out…" 🥸 😎 😇 😌 🥺 😵‍💫 🤒
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Hi,
Cheers
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART ALSO FLY LEGALLY.
obanat
