How to preview a flight session on my CrystalSky Monitor
Giaruso
After a Litchi Waypoint flight with my Mavic Pro, I would like to view that flight on my CrystalSky monitor before leaving the flight area. How do I do that?
Reason: Well, after completing the preprogrammed flight, I'd like to see how the flight looks should I like to re-do the flight with different parameters. Any help will be greatly appreciated.
Before you leave the area with your drone connected to the controller and the crystal sky all turned on just hit the play button on the screen and you can see the flight you just completed if you recorded it on the simcard in the drone
Were you aware that there's a Chrome Extension to allow Litchi VLM files to be created and downloaded. You run the VLM in Google Earth and it not only runs the route but you're getting simulated views of where the camera is pointing. I find it very helpful.
Edit: I realize you want to look at it after the fact, but it's pretty awesome to run a simulation ahead of the real flight to double check camera angles and the like.
Sharky05, I tried what you suggested, but I haven't yet been able to find the "PLAY BUTTOIN?" I pushed everything on the CrystalSky screen and nothing happened. I am using a Mavic Pro with an ANDROID operating system. Please tell me what that button looks like and where it is located on the screen.
Hello mate I know this is on the i pad but if you look at the crystal sky it should be the same I will ask my son to bring it down with him tomorrow to double check it. But that's what you should see on the screen see the play button below the record button try angle in white square.
Ok mate here's how to check your photos. On the home screen see where it says applications click on that then gallery and all your photos will be there to check. Hope this helps you.
Reactions: Giaruso
bullet_magnet
