iPhone IOS 11.1
Just reinstalled the GO4 app
Did you do a complete reboot of your device prior to reinstall the app?
To get rid of some remains of an app, i
a) uninstall app
b) reboot device
c) install app
a) uninstall app
b) reboot device
c) install app
I think so? I turned the iPhone off, let it set, then turned it back on again. That's the only way I know to boot it?
If you were pressing and holding the ON/OFF switch for a few seconds and you saw the slider 'Turn off' slider on the screen and you actually turned OFF the device, then you are good.
That's the way I did it! Still no luck, once it acted like it was "connected" then asked for a update,I declined it and the app froze up. Next time I accepted it and it dumped while it was supposed to be updating the app? I finally got the app to come up, but it freezes and won't let you set anything! The multi flight modes won't switch or anything else work?
Stupid question: Are u connected via the short USB cable to the left side of the RC?
Yes,and I've tried the using a cable in the bottom USB port,nothing changed? You get a different screen (nonfunctional) every time you power it up!
Phuuu, then i'm running out of ideas ...
Reactions: Ron_Dog
I updated to IOS 11.1 beta and had exactly same issues. But now iOS 1.1 is public release and more pilots are experiencing issues. Now iOS 11.2 public beta is out. I won’t upgrade until it is public release and wait for DJI to fix compatibility issue with iOS 11.1.
Reactions: Ron_Dog
Yeah,I didn't wanna fly anyway! LOL!:rolleyes: But I still can using the iPad Air 2? I just don't like how big it is, but it's working perfectly! WHY? I don't have a clue? This MP had over 130+ flights logged on it without a single Hic Up! Now this Garbage!:mad: Why can't DJI leave well enough alone? I don't care about "Quick Shots" or any of the other modes. I just wanna fly, have the drone fly where I point it, and take pictures/video's! (I bet if I lay down a bunch more cash for a "Crystal Sky" it will work perfectly)!:rolleyes: The iOS phones/tablets were working good, maybe too good?
Sorry, that’s not rebooting the device, that’s simply switching it off as in sleep.
Depends on your Idevice but if you have a home button, this is the correct reboot process.
Press and keep holding both Home and Power buttons for over 60 seconds till the screen goes black then a white Apple appears.
Keep holding till the white Apple disappears.
Then release both buttons.
Now power on the device.
There will be a long wait while a full memory defrag takes place then you will have to enter your password.
That’s a full proper hard reset of a iPhone, iPad etc.
Reactions: Ron_Dog and Keule
.I tried it, no change?
But if I use the O'l Trusty iPad Air 2,Bingo!:D All systems are GO!iPad Air 2100_0936.JPG
iPad Air 2100_0937.JPGiPad Air 2100_0938.JPGiPad Air 2100_0939.JPG PS. There's no way I'm hitting that update button!
Forgive my iPhone ignorance, I have a iPhone 6, if I do as you suggest will I loose anything I have put on my phone ?
No. you are just rebooting it. to loose everything you will need to reset you phone under the "gear/general/reset" tab. do that if you are really have trouble with your phone and nothing else seems to work. it is recommended you do a hard wire iTunes back up to your computer of your phone before reseting so you can reload all you apps and data.
Thanks locoman for that info.
I intended to see if I experienced the same problem with iOS 11.1. As it turns out I only have iOS 11.0.3 installed. Flying and recording video worked fine. So until DJI or Apple fixes problem, I will stay here.
I checked the App Store and I DJI Go 4 version 4.1.16. I am waiting to see if anyone has found that this version of Go 4 works with iOS 11.1. It sounds like that is not the case now.
I have another issue though. As you know, iOS 11 came with a screen recorder. I have used this successfully in the past and found that it works great, except that the mic turns off once you are in the DJI Go 4 app. Is that what others have found? That seemed to be the case today as well with iOS 11.0.3 and the latest Go 4 app.
Reactions: Ron_Dog
Welcome to the forum don, I have just updated to the 11.1 ios and the latest Go 4 app, but I have not seen the screen recorder you mention I'll have to go and look.
susnzhe
