Kingston 64GB Extreme Micro SD Card will create Corrupted Video File
Rgrimard
Currently in Arizona Back in Maine come May
My Mavic Mini-2 has been Corrupting my 64GB Extreme Micro SD Cards, I'm now on my 3rd one. Has anyone
else seen problems with Kingston 64GB Extreme SD cards? If I look at the files on the SD Card it will show Photos and
Video that was taken. The Video format is MP4 about 3.4GB and its all Milky looking and
does not play. When I delete that Corrupted file and Reformat the 64GB it will not Connect to the Aircraft. When I put in
a new Factory Kinston 34GB Extreme the aircraft Connects to the Controller... I'm not sure why this is now starting to happen. It does happen each time I fly thats the strange part.
Use another brand to isolate the problem to the AC.
Don't think Kingston don't make an "extreme" branded card, did you get fakes ?
Hello Rgrimard:
Sorry to hear of your corrupted video files. Good advice provided upthread by others. In addition, If you’ve been formatting the card on an external device before placing in the drone, you might try formatting in the drone via the DJI Fly app. In other devices I’ve had luck with that technique.
Howard
RYNOGOD
