Landing issue with MA2
714Aberdeen
Hello i just received my mavic air 2 and I’m having a problem and thats when i want to bring down the drone , its lands in a very very slow . Even though I put down the stick downwards. Also I faced this issue in RTH and also with all mode in the controller normal and sport
Other direction is ok just in landing
The drone was about to crash twice since the battery was going to finish
Does anyone have the same problem? Is it something wrong with the software?
Think the first we need to do is to look into a flight log from a flight where this happens ... this to see if the descend speeds is on par with the specs or not.
Go here & read up on how to retrieve the mobile device .TXT log --> Mavic Flight Log Retrieval and Analysis Guide (read under section 3.) ... attach then the log in a new post here.
is the volume on you phone turned up? was it beeping or talking to you while you were landing? It could be the collision sensors were detecting you or something else in range.
Reactions: PhenoUAV
dominicus15
