It tries to determine if it's safe for the Mavic to auto land when it's near the ground. Here's what the Mavic manual says about it:
When disabled, your Mavic will not auto land after manually initiating RTH or using the auto land feature. Instead, it'll hover when it descends below 0.5 meters and wait for you to confirm that it's okay to land.
honestly i just leave mine off and i have never had any issues i can cancel RTH landing myself at any time.So, whats the conclusion? To me it seems the only practical use for landing protection is flying close to the surface, or, for example, examining a roof, while out of LOS, not knowing exactly how high above the surface you fly. In this case the function "may" protect you from hitting the surface. Other than that - i am not sure.
Personally, I don't use the swipe to land or take off but I still have my sensors running. When I first started I would religiously use the function until I was comfortable with landing and taking off by myself. Now, I use it very sporadically i.e. when someone wants to see all the features of the bird. I still don't think it makes me a poor pilot. It's a feature I would rather not use. It's like cruise control in a car. How often do you use it? Do you think you are a poor driver because you are letting the car (technically) drive by itself? There are know and well documented cases of cruise control going freaky YET we still use it. Same case.Would you use it if you knew that in several common cases it would cause undesirable behavior?
For me this is the pros and cons of this feature:
Pros:
Cons:
- Safer low altitude hovering above objects/surface out of VLOS.
The bottom line is, I've kept this feature disabled pretty much since the moment of the original post, experiencing zero issues as a result of disabling it. I may re-enable it as needed, but will usually fly with it disabled.
- Interferes with hand catching/launching.
- Dangerous while flying in tight spaces with limited vertical clearance.
- May cause annoying "not suitable for landing" false alerts.
