I suppose it depends on how it lifts. when you calibrate the IMU it has to be done on a level surface, so your Mavic knows what level looks like. So if you put it on a sloped surface it presumably knows that this is not level. Assumption I make here is that when you ask for take off it will lift level, i.e. if pointing up hill the tail will lift until the aircraft is level before actually getting airborne. If it does do that then the danger is that the front props will strike the ground infront of the aircraft. more likely if the aircraft is pointing down hill, the tail props hitting the ground.
At some point it must regain its idea of level, otherwise you would be flying about nose high or nose down.
As I always look for a level take off point, level to me anyway' not really experienced a really sloped take off and I hand catch if landing on anything other than a solid surface.
Ive tried various grounds/inclinations and everything is fine.
I did try a humid/wet rock that had certain inclination - once the propellers fired up, the drone started drifting because it didnt grip the rock. Had to lift it up pretty quickly.
Full disclosure, I takeoff and land in horrible conditions. I have hand caught only twice. The Mavic, because it has a much wider base, is far more stable than my Phantom. The Mavics feet are located almost directly under the props and the center of gravity is low. It almost impossible to tip it over.
Yup, that's the easiest way. Also, as another poster has said you can also hold the controller to your body and get the sticks inwards with one hand.
By the way, I've had none of the auto launch motor cut off problems that have been reported in other threads, but I rarely take off with a battery that's any less than 80%.
I hold the Mavic in my right hand and use my right elbow for the right stick. That way the controller is always firmly in my left hand. I still get good clearance away from my head this way.
Ah I see thanks for the replies. Must try that auto take off button. Forgot it was even there - although I suppose I use the equivalent all the time when I hit the Play button for a Litchi WPT mission.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
