zeeeegerman
Hi all,
Those new to the DJI Ecosystem, or even those that have had a DJI drone for a while may learn a few things in this video.
A few points:
-advantages of using the DJI Assistant 2 on a PC
-When you should and should NOT update the firmware
-Critical Steps after a firmware update
If video isn't your thing, you can view our written Mavic 2 Firmware Update Guide Here.
Reactions: Larry Gibson
He missed one method. If you hold down the three bars on the DJI screen of the Go4 app for 5 seconds and release a screen appears that will let you select which firmware version you want or refresh the current one, just like the Assistant.
Hi Robert, thanks again for that tip, i tried it tonight and was pleasantly surprised of the page that popped up. I guess if your already on the current version it says no firmware available. The page def. has a beta vibe to it. Probably built in workaround trick for DJI support people to guide you through if you have issues. How did you find out about it?
Reactions: Robert Granata
All props go to Billy Kyle on YouTube. I had never heard about it before his recent video. I think you are right about it being a workaround. Probably for all the people on windows that can't use DJI's unsigned USB drivers.
I did try it on the Mavic Pro and there were about 5 previous versions you could downgrade to.
That built in trick has been in DJI GO since DJI released the Phantom 3 models.
Andrefu
