Mavic 3 pro controller battery life
Hiwayman
Yorkshire. UK
Guys
I'm curious how many batteries does your aircraft fly on a single charge of the remote (with screen)....I'm getting less than two aircraft batteries before controller is beeping at me...☹️
Guys
You did not specify which RC you have but all of the 3 compatible RC's should easily last for, at the very least, 2 hours.
A typical Mavic 3 flight is 25 to 30 minutes (landing with around 20% battery left). If you are only getting 1 hour from your RC then you likely have a bad battery in your RC or there is some problem with the RC that is causing it to draw too much battery power.
Reactions: Hiwayman
I'm easily getting all four batteries (down to 30%) without needing to recharge.
Reactions: Hiwayman
Olga
