Yesterday I was flying my mavic air and suddenly went from 56 % battery to 0. Last spotted in a very swampy area? Anyone ever experience an issue with the battery doing something similar?
Do you have the flight logs from your mobile device? If so, please post them here and that may give you some answers.Yesterday I was flying my mavic air and suddenly went from 56 % battery to 0. Last spotted in a very swampy area? Anyone ever experience an issue with the battery doing something similar?
Did you takeoff with 100% fully charged battery?
@Jcastro1836 .... Post the video on your YouTube (or other media place) channel. Tap the “share” button and copy the link (usually automatic). Post the link as text in your post. Then it will be there as will a preview pic.Definitely started at 100 percent battery. My flight history shows it drop from 54% to 0 in aBout 4 seconds. Tried to upload the video here but only lets me uploads pictures.
Indeed I have! See MA battery failure scare for details.Yesterday I was flying my mavic air and suddenly went from 56 % battery to 0. Last spotted in a very swampy area? Anyone ever experience an issue with the battery doing something similar?
rare yes but not impossible battery puffing and violent stops and manouvers flying in sport mode can and have caused batteries to fall out
The flight logs would be far more informative than the video:
How to retrieve a TXT log: DJI Flight Log Viewer | Phantom Help
[["2019-11-16 11:53:42","","Home Point Recorded. RTH Altitude: 30m."]],[["2019-11-16 11:54:02","","Home Point Recorded. RTH Altitude: 30m."]],[["2019-11-16 11:55:30","","Strong Interference to Aircraft. Signal interruption may be more likely. Fly with caution."]],[["2019-11-16 11:56:03","","Attitude is too large., Backwardobstacle sensing is unavailable."],["2019-11-16 11:56:12","","Strong Interference to Aircraft. Signal interruption may be more likely. Fly with caution."]],[["2019-11-16 11:57:19","","Attitude is too large., Backwardobstacle sensing is unavailable."],["2019-11-16 11:57:29","","Signal Lost. Aircraft returning to Home Point"]],[["2019-11-16 11:57:53","","Strong Interference to Aircraft. Signal interruption may be more likely. Fly with caution."]],[["2019-11-16 11:59:34","","Weak signal. Adjust antenna and avoid signal block."],["2019-11-16 11:59:40","","Attitude is too large., Backwardobstacle sensing is unavailable."]],[["2019-11-16 11:59:59","","Critically Low Voltage Warning\nAircraft Landing"],["2019-11-16 12:00:00","","Battery power limit will automatically reduce the aircraft's mobility to ensure flight safety."],["2019-11-16 12:00:04","","The remaining battery is only enough for RTH. Return home now."],["2019-11-16 12:00:04","","Critically Low Voltage Warning\nAircraft Landing"],["2019-11-16 12:00:05","","Battery power limit will automatically reduce the aircraft's mobility to ensure flight safety."]],[["2019-11-16 12:00:33","","Weak signal. Adjust antenna and avoid signal block."]]
Just feel like this doesn’t show how the battery jumped from 54 to 0
Not the proper flight logs we are looking for...Yes here they are.
