Dabrain
Let's see op is a newbie, but a well known member of the forum and flew to 9,000 feet altitude. Something smells.
Say it ain't so!!I think you are the one kidding everyone else here
Are you changing your settings when connected to your mavicI set mine to Imperial units, but it still asked for the altitude and distance in meters. What am i doing wrong?
I wonder if there's a physics difference then in 6,000 ASL/6,000 AGL vs 12,000 ASL/6,000 AGL?1/2 the people in Colorado wouldn't be able to take off if the max was 6000 ASL. I've flown as high as 12,500 ASL.
I live at 8400 feet and a lot of my flying is higher then that!I wonder if there's a physics difference then in 6,000 ASL/6,000 AGL vs 12,000 ASL/6,000 AGL?
Hahaha!!Didn’t get your answer here huh .Modifying Altitude Settings?
It won’t fly away 9000 meters in any direction. That is 5.6 miles. In miles, however, it’s 1.7 - possible. About you knowing your measurements - no comment.500m?... I live n the USA but when I was flying my Mavic Pro earlier today I put it in the shy and I could not see my drone but when I looked down at my DJI GO 4 app. the altitude numbers were 9057.. Is that meters or what? I am new to the drone stuff.... Finally I hit RTH and it took quite a long time to get back.... I am a newbie.
Is the U.S., the maximum legal altitude is 400 feet above ground unless you are within 400 feet of a building or tower. Then you can go up to 400 feet above that building. This rule is designed to keep you from interfering with manned aircraft. Be safe and follow the rules. You might learn them first.Whats the Max Altitude out-of-the-box my new drone will go?
Not entirely correct, 400 ft over a 400 ft tower puts you 300 ft above maned aircraft minimum altIs the U.S., the maximum legal altitude is 400 feet above ground unless you are within 400 feet of a building or tower. Then you can go up to 400 feet above that building. This rule is designed to keep you from interfering with manned aircraft. Be safe and follow the rules. You might learn them first.
NotedNo, for a Part 107 pilot, that is correct. From the FAA rules: "You can fly during daylight (30 minutes before official sunrise to 30 minutes after official sunset, local time) or in twilight with appropriate anti-collision lighting. Minimum weather visibility is three miles from your control station. The maximum allowable altitude is 400 feet above the ground, higher if your drone remains within 400 feet of a structure. Maximum speed is 100 mph (87 knots)." (Fact Sheet – Small Unmanned Aircraft Regulations (Part 107))
The 500-foot minimum altitude for manned aircraft is over terrain or over structures. You can't buzz by the windows of a 750-foot tall tower at 600 feet just because you're still technically above the minimum AGL height.
And of course neither if you is correct for recreational flyers, as there is technically no legal height limit - only an advisory.
Are you in beginner modeA couple of times when taking off, I have received a message about maximum altitude of 100ft reached and also a limited distance from the home point. (not sure of exact distance) and that I can change it in the "main controller section"
When i look at my altitude settings, it is still set to my the normal 400ft. Anyone have insight to what is going on?
No I am not.Are you in beginner mode
