New Air 2s pilot
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Below is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Air 2S - Download Center - DJI
Happy and Safe Droning…
Welcome to the forum! :)
Welcome to the forum! If you need any product support or help, please do not hesitate to let us know. Also, we would like to offer you a 5% discount on our online store: www.FloridaDroneSupply.com - Use Code: NEWFORUMPILOT at checkout! Have a great day!
*Discount does not apply to DJI Enterprise Drones.
bullet_magnet
