New DJI Mini 2 pilot from Manhattan, KS.
Welcome to the forum! :)
New to the DJI forum coming from an AR Parrot drone to the Mini 2 drone
Ok, some small humor time… Since you are now flying a DJI Drone verses the Parrot, it can be said, "You are not in Kansas anymore…" It's a world of difference…
Even though you are not a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Kansas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
All DJI Downloads……………………
Mini…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Mini SE…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Mini 2…………………..…………………..
Mini 2 SE…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Mini 3…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Mini 3 Pro…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Air 2…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Air 2S…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Mavic Air…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Air, including the User Manual.
Mavic 2…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Mavic 2 Enterprise Series…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 2 Enterprise, including the User Manual.
Mavic 2 Enterprise Advanced…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 2 Enterprise Advanced, including the User Manual.
Mavic 3 Classic…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 3 Classic, including the User Manual.
Mavic 3…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Mavic 3M…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 3M, including the User Manual.
Mavic 3 Enterprise…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic 3 Enterprise, including the User Manual.
Mavic Pro…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Mavic Pro Platinum…………………..…………………..
Below is the link to all of the downloads offered by DJI for the Mavic Pro Platinum, including the User Manual.
Welcome to our forum, from Hauptmann, in Hurst, Texas!
Don't you love the flexibility of vantage points an aerial camera platform affords--we get shots and videos we could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
We have over 150,000 members—many from the Plains States--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy. They specifically refer to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
Hello from Minnesota and welcome to the Forum....Congratulations on you Mini 2....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
New to the DJI forum coming from an AR Parrot drone to the Mini 2 drone and so far really liking the difference.
Welcome to the forum the Colorado Rocky Mountains! Happy and safe flying!
WTF-N1466
