Could this replace a tracker (trackimo, marco polo, etc)?Works great....brings up a map showing the last known position of the aircraft. (Similar to "find my iPone")
To some extant, if you lost connection before you lost your drone this will only show the last known (connected through app) place.Could this replace a tracker (trackimo, marco polo, etc)?
I believe this shows a lot. Maybe DJI would like to mimic Apple's find my iDevice feature. Perhaps in the future, they could enhance this service in a way so that if someone loses their drone and someone else finds it and try to use it, you would be notified through that screen of your drone's last known location. Even better, they could even send you a notification in real time as soon as your drone's location is captured. This could be just a start, but towards to a right direction. Just thinking....Works great....brings up a map showing the last known position of the aircraft. (Similar to "find my iPone")
Did you update your controller as well?Apologise if this has already been asked but I upgraded through DJI Assistant but in the DJI Go App it still says "firmware upgrade required", is this a common issue
Yup, or you can do it through the app, but since your drone is updated I would just plug the controller in to the computer.Not sure? How do you update the controller? Same as the drone and plug it in to a USB port on your computer?
The most interesting and "useful" part of this update is the ability to silence the remotes low battery warning! Hopefully the mavic low battery warning is next!
Hi mate, tried so many times now, getting a bit peed off, on DJI assistant 2, updated remote no problem, aircraft will not, so I downgraded to V01.03.0400, all ok, upgraded to V01.03.0550, all ok...then upgrade to V01.03.0600, hangs at 57% then fails, upload error 0x020106, Wtf?
I am waiting for the goggles to come out for fixed wing mode however I have seen some videos of it.Has anyone tried the fixed-wing mode?
