DroneTone
Didn't work for me, unless your suppose to hold the button.
The method of muting the RTH beeping by pressing the RC power button once didn't work for me either...
Nathan "follow me" mode works in your Mavic?
I downgraded to .0550. I was not having the drifting problem people are talking about, but the gimble issues were driving me crazy. I just flew a full battery with no gimble or any other issue.
On the Play store page you should see an option top right to update automatically (check box)Just in case anyone who tries to update to this latest version and gets the message "unfortunately DGI GO 4 has stopped" every time you try to apply the firmware update.
I found that for my Galaxy S5 my DGI GO 4 app the app needed updating from the playstore. Once that was done it worked fine.
Didn't realize the DGI GO 4 app didn't automatically update and that you have to check and do it manually.
Yes, today was very odd. The first time was while I was still on the ground. The horizon tilted about 45 degrees to the left, then slowly started to correct. It took about 2 minutes for it get back to almost level - but it never actually got level. This exact thing happened mid flight as well. 45 degrees slant, but this time it never corrected. I had to land and recycle power.What kind of issues with gimball? I did have some strange problems today with the gimball gone crazy......never had before with .0400 ( First issues with .0600 )
I know you can have up to four different stick configurations (see manual) but not sure if this applies to new feature? A lot of times software takes baby steps so I am sure it will sooner then later if not already. I will check out if the wind dies down...Useless unless the flip the left control so pushing up flys down and pulling back flys up like an actual fixed wing craft. Unless there's already a way to flip the direction?
Since I went back to .0550 I have flown 3 batteries now and the problem has not come back.
Not sure what I would use this mode for. Any ideas?Noticed a new firmware this morning with a new feature: Fixed-Wing mode. Haven't tried it yet, but sounds interesting. It's described in the new manual as:
Fixed-Wing Mode
The aircraft will fly forward automatically at a certain speed after entering Fixed-Wing Mode. Push the left
stick up to ascend and down to descend. Push either stick left or right to rotate the aircraft. Pushing the
right stick up will accelerate and pushing down will exit Fixed-Wing Mode.
In the DJI GO 4 app, tap the icon and enable Fixed-Wing Mode. Push the right stick up until the C1
icon appears, then press the C1 button on the remote controller to enter Fixed-Wing Mode. Push the right
stick down or press the C2 button on the remote controller to exit Fixed-Wing Mode.
Once it stucks at that, just restart the mavic (and only mavic) the upgrade will continue.Same here...wont update
When doing the firmware update and it gets to the part of updating NFZ, does it freeze on you? It does for me. Have yet to update then when I updated to .550 and .600
How do you downgrade firmware?
Same here but I went back to 400 this new .600 update is a total disasterYes, today was very odd. The first time was while I was still on the ground. The horizon tilted about 45 degrees to the left, then slowly started to correct. It took about 2 minutes for it get back to almost level - but it never actually got level. This exact thing happened mid flight as well. 45 degrees slant, but this time it never corrected. I had to land and recycle power.
