Mavicjon999
- Joined
- Mar 19, 2017
- Messages
- 109
- Reactions
- 28
- Age
- 52
Downloaded .600 today.Test flight tomorrow but after all the bad reviews on here kinda nervous...flew on .550 perfectly.
Mad, no doubt what you say is true. I was heading over to an Easter Egg Hunt and I wanted to put the MP up high and from the side over private family property, and film the whole hunt from above. Which I did do successfully. Because the 0.600 firmware on my MP at the time was not giving me the confidence I wanted and needed, I rolled it back.With every update there is the usual it don't do this or it's now doing that.
Reality is it takes months to know what fw is the most stable.
What I would always advise is people updated fully check every setting and reset camera settings then fly it 10 times minimum, you can not really budge issues from one flight, people will always say I have less range or it does not fly the same but after a few days these things usually fall away.
I have flown this fw a lot and I have not found an issue with it.
What was your tilt balance issue? Just curious.... I never noticed my camera not being leveled until I went to 0600. I did hours of flying on prior firmware and never noticed any issue. After I upgraded to 0600 I noticed my camera level was off. Checking Gimball Roll Settings and it showed -0.1 which I assume was factory setting because I never touched this since I've owned it.Yes, now that I am on .0550 it is back to normal. No issues.
No gimbal function in this mode!!I guess this Fixed Wing mode - if truly released - is the Easter present from DJI Looking forward to more cinematic moves! Should help us focusing on smooth gimbal movements while automatically forward flying.
I fear you may be right. I'm safe on .400 and need to stop being suckered in to trying the latest thing.I wonder what the posts will be like when the music stops and chair number 4 is gone!
Rob
All went well.Aircraft and controller back on .550 but app is still on 4.0.7.....is this right and ok to fly with ?
