NEW GUY ON THE BLOCK
I have a Mini 3 Pro bought in June 2023 but selling it now and going up to the Mavic 3 Pro
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro and the Mavic 3 Pro, including the User Manuals. If you sell the Mini 3, you can pass the link ionto the buyer…
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the forum! :)
Reactions: LoudThunder
Whitehammer661
