Thank you!
Welcome to the forum from Hauptmann in North Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro..
Our more than 150,000 members worldwide enjoy helping each other get the most out of our hobby. Many of the questions you'll have will have already been addressed, and are easy to search. New questions? Just ask!
Glad to have you with us!
Rich R (aka Hauptmann)
p.s. Be sure to follow LoudThunder's and GFields' advice.
Greetings mate, welcome to the forum from the Northern Territory. I’ve used the mm2 for some photogrammetry work, but not for any thing requiring a high level of accuracy, not that it can’t be done.
Regards
I have found some tutorials online and on youtube and will give it a go very soonish!
Since you live in Tasmania, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
Hey Loudthunder, thank you for this very comprehensive response mate, must have taken some time for you to collate all these advice. I have landed on sand yesterday so a bit worried if ever sand particle might cause some damage, looking to get a fine brush and get as much sand i can out of the small beast.
Cheers mate 💪
I've checked the members map and unfortunately there are none where i am, northwest coast of Tasmania :(
Hello Hauptmann,
Thank you for the welcome my maan. I captured some footage over the weekend along the shoreline where i live and a bit further and it is spectacular to say the least. The only thing i am a bit annoyed about my flying is how abruptly i tend to rotate my camera to the left or the right, which breaks the cinematic effect i'm after. I'm looking to smooth my movements to add fluidity to my footage. Other than that, happy days!
Welcome to the forum! :)
Google "Drones and model airplane clubs in Tasmania"
Here are some that I found, I do not know how far they are, but if you want it bad enough…
And the list goes on…
Good Luck.
Saikiran Villa
