Newbie from New Jersey
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. Many discussions on this forum about flying in your region. You'll find your answers here . . . good luck pilot!!
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. I too am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). Open the front legs, open the back legs of your drone, then remove the Gimbal Cover.
Place the drone down while it finishes its self-test (collecting satellites, etc…).
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby;"
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page Mini 2 User's Manual, in case your Mini did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Downloads - DJI
Happy Droning
Welcome to the forum! :)
birdevyview
