no what did you do please explain for us newly uneducated pilots who like to use functionalityThere's no shame in using RTH,it's convenience and most importantly it's user preference..
See what I did there?
only when i am with my daughter and GF at the same time and both are grumpy as hellAwww....you didn't noticed the double period.
I've never used RTH although I should just to test it as others have pointed out, I prefer to keep full control over the drone as much as possible and use RTH when something has gone wrong.
It is no different than using cruise control in your car. There are times that you want to use it and others when you don't. It is a great feature to have available for when you want it or actually need it.
To each his own......options are great for the end user. I have had zero issues (knock on wood!) with using RTH and I have used it over 50 times to-date. And setting up the RTH altitude takes seconds if you even need to change it for a given flight/mission so I wouldn't consider this to even be a factor.Cruise control rarely cuts out, lots of things can ans do go wrong with rth I have never used it, been flying for so long we never had them features. Also things change in the 20min or so of flying you stay out longer etc and rtm isn't any guarantee to actually get back safe. I stick with los and manual an can't complain as I fly 95% places I have never been and trying to spend all the time to set rth height etc not worth it. I do use auto take off every time, just on the off chance simething crazy happens and loose connection, might have a chance it comes back
In the early days I had customers come to me asking me to build them a drone. I would design them per application. So if you wanted one for DLSR missions then it would be made for that. If it was for mapping or inspection or fun ect. I would provide log books, check lists and user manuals. But, while it was being built I would also provide them with a foam shelled toy multi rotor to learn to fly on. The RTL , barometer control, compass , GPS ect, if it all was taken away in an instant , being able to control the flight from experience is I invaluable when it comes to saftey. I agree it's good to test but I'm like most. Use it only when absolutely needed. Control over your aircraft is best in my opinion.I reckon most who use it every flight, as well as auto take off and land, would learn a lot more by manually flying home and landing. You will be a better pilot if you don't rely on these automated features.
It has auto take off too, but why would you use it? Some cars still have cigarette lighters, by your logic, its meant to be used so I guess people should take up smoking to make use of the cigarette lighter .i use both, why not? that is what the modes are for, sometimes i have done what i want or need to do and someone will want to chat and have a smoke etc etc.
Then yes i will hit RTH, why should i not trust these systems, that is what i paid my money for too. if i cant use them i might as well just buy a cheaper drone and be done with it.
i have used RTH many times, like i say sometimes there are other distractions going on which makes RTH perfect even just for having a smoke break before another flight, chatting to people who come up and wanna ask a lot of stuff about the drone (great way to reassure people drones are safe and can do this kind of stuff).
It is normally one of the first things i am asked "can it fly itself"
and i love the gormless look on their faces as they stare into the sky for 5 minutes trying to spot a drone and they only see it when i ask em to move out the way before it lands on their heads.
Tech is built to be used, i don't buy a car and leave it in my garage in case it breaks down, or never use the seat belt just in case it does not work, or use the satnav in case i end up in a river.
If it has a use and a function i will use it.
