Scotland New Flyer
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Hi PJordan Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Mini 2 manual HERE
You want an SD card that is U3 for 4K
Most of all have FUN
New flyer advice,
Wide open space.
Slow & easy
Thank you. This is exactly the info I need starting out, much appreciated.
Welcome to the forum! :)
Just got my new Mini 2 here in Edinburgh
Here are some things to help you get started with your Mini 2:
  • The current Mini 2 manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mini 2 downloads page.
  • Check out this getting started guide for some tips not found in the Mini 2 manual.
  • This video covers all the basics of the Mini 2.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
sverkerh
