So on the same clip, on same frames sometimes you have lines and sometimes not? Or is the lines always present in same place during each playback of clip?sometimes when i view or play the videos some frame have streaks and lines in them other times video is ok what is causing this ? or am I using too high of a resolution ?
You're really going to have to post an example for us to be able to help you. Otherwise we're just guessing.sometimes when i view or play the videos some frame have streaks and lines in them other times video is ok what is causing this ? or am I using too high of a resolution ?
yes I should and I will thank youYou're really going to have to post an example for us to be able to help you. Otherwise we're just guessing.
sometimes during the spining of the drone thiis happens but then it clears up when I dont turn yes horisental sometimes green linesSo on the same clip, on same frames sometimes you have lines and sometimes not? Or is the lines always present in same place during each playback of clip?
You say lines, are they horizontal like screen tearing?
Are you recording in 4k?
What are you playing back on?
NO MOSTLY DURING PLAYBACK ON A FEW FRAMESAre you seeing them as you are flying sun ward. maybe prop showdows .
THEN PUT UP A CLIP SO WE CAN SEE .NO MOSTLY DURING PLAYBACK ON A FEW FRAMES
That looks like prop shadows. Common in sports mode, low sun and wind.Since this is a topic about lines on video, I’ll throw my lines in. It’s pretty uncommon but it does pop up here and there. Any idea what this is? Normal? No the lens hood is not on. Yes it is windy.
I KNOW THEY ARE CORRUPTED AND I AM ASKING YOU WHY?Those are corrupted files... Which either happened while they were being shot, or once they landed on your hard drive. Have you formatted your microSD card WHILE IT IS STILL IN THE MAVIC? You should ~as a starting point...
question was not about the prop shadows , it was not sport mode ,was plenty of sun ,and no wind , why are the video streaking with lines ?That looks like prop shadows. Common in sports mode, low sun and wind.
yes formated sd card several times on the droneI KNOW THEY ARE CORRUPTED AND I AM ASKING YOU WHY?
Assuming the files were off SD and not cached start with your memory card.I KNOW THEY ARE CORRUPTED AND I AM ASKING YOU WHY?
Have you tried a different card? What are the specs on the card you are using? The card will remain a variable in this equation until it has been eliminated as the cause...yes formated sd card several times on the drone
brand new card came with drone sure its good qualityHave you tried a different card? What are the specs on the card you are using? The card will remain a variable in this equation until it has been eliminated as the cause...
