Sunshade
MoOriginal
Has anyone come up with a solution for the problems associated with the front mounted camera and not underslung like the phantoms.
Im constantly battling sunflare or prop shadows in my shots.
Not a problem I had with the P3
Im hoping this thread jogs someones memory as to a solution.
Ive seen one on YT where someone hacks(cuts a hole into) his gimbal cover painted to black and works very effectively.
But Im hoping someone has a cleaner solution where they produce a 3d printed file or version.
Thanks
Mo
PS heres a pic i took when im not battling sun flare.
This is the mod im describing
Although not hard - if someone just came out with a proper solution I may have to go down this route and do it manually (only with a dremel and not a drill ;-) ).....
Reactions: jerryflah and Loz
Thanks
Mo
That's a great pic, was this with the Mavic?
Reactions: MoOriginal
I think I would buy a spare gimbal cover from DJI so that I still had one for protection purposes but it's a good idea definitely
Reactions: CaptTPT and Fanbelt
Thanks
Mo
Just wanted to say that is one beautiful pic, congrats!
Sent from my SM-G935U using MavicPilots mobile app
I saw this on my phone last week and tried to post it but failed
Seems like a simple and doable project serves to add a limited amount of gimbal and camera protection as well
I made one following the youtube video instructions and it took me all of 20 mins from start to finish. It doesnt have to be that accurate - the most important part is shielding the sides. Using a dremel it was a piece of cake. Very happy with the result and glad that I went the DIY route (very satisfying when you get it right!).
Here's mine, I opened it up a bit more than his suggestion. Works great. Brilliant idea, thanks.
Sent from my XT1585 using MavicPilots mobile app
Done searching I am, results I have.
DJI Mavic Sun cover
The left side needs to be adjusted I think, you can see a hair of it in the sample video.
Watched the video - it looks like there the abs printed material needs to be harder.
You can see the edge of the cover flapping in the wind from the props I assume.
Still you could I guess print it in thicker abs or different material from a 3D print place that could if needed.
I took a run at the lens hood mod. Pretty easy overall. Just take your time with the layout. This one is sprayed out (on the inside) with plastidip. I'm happy with it.
GLobus55
