It must not have went well. I would have expected some gloating the minute the hearing was over if he met with positive results.
IF he won, it would be interesting. At least for California state parks. But they could just as easily tighten up the regulations.FWIW I'd still love to know the outcome. If he won (which is very doubtful) it could set a precedence that could ripple across the country.
I hope he lets us know. I had no luck finding the court report online.
Maybe he shared the same attitude in court as he did here and drew a contempt charge? He's not responding because he's in a cell! (I know thats not how it works, but it'd be funny)IF he won, it would be interesting. At least for California state parks. But they could just as easily tighten up the regulations.
So, similar to national parks - if one were to launch and land outside of the property of say a no-drone-zone city park - the local authorities cannot govern our flights *over* that park...? I'm just trying to clarify, as nothing drives me more insane than a person rattling-off a list of violations, that I (we) haven't broken.
Thanks for the "cut and paste"I recommend that all sUAS pilots should immediately begin using the relatively new FAA program called the Low Altitude Authorization and Notification Capability system or (L.A.A.N.C.).
This is a collaboration between FAA and Industry. It directly supports UAS integration into the airspace.
It provides access to controlled airspace near airports through near real-time processing of airspace authorizations below approved altitudes in controlled airspace.
How does it work?
LAANC automates the application and approval process for airspace authorizations. Through automated applications developed by an FAA Approved UAS Service Suppliers (USS) pilots apply for an airspace authorization.
Requests are checked against airspace data in the FAA UAS Data Exchange such as temporary flight restrictions, NOTAMS and the UAS Facility Maps. If approved, pilots receive their authorization in near-real time.
LAANC also provides FAA's Air Traffic visibility into where and when planned drone operations will take place.
How does LAANC benefit me – The drone pilot?
Under the small UAS rule, pilots or operators planning to fly in controlled airspace under 400 ft. must receive an airspace authorization from the FAA.
LAANC dramatically decreases the wait time experienced with the manual authorization process and provides greater flexibility in operational planning.
Through LAANC pilots and drone companies can:
Note: If you are planning an operation in controlled airspace that requires a waiver AND an airspace authorization you must apply for both through the Drone Zone.
- Apply to receive a near real-time authorization for operations under 400 feet in controlled airspace around airports.
- Request to fly above the designated altitude ceiling in a UAS Facility Map, up to 400 feet. Applicants may apply up to 90 days in advance of a flight and the approval is coordinated manually through the FAA.
Approved LAANC UAS Service Suppliers
The following companies have completed the technical steps required and entered into agreement with the FAA to provide LAANC Services:
This list will be updated as additional partners are approved.
I have been using the LAANC system ever since it was available in southern California. I use the AIRMAP app to access the LAANC system and I think the system is GREAT. The system allows sUAS pilots to program their own flight plan and submit it directly to the FAA for approval within 60 seconds. As the sUAS pilot looks at the screen on their iPhone or Android cell phone using the LAANC. The sUAS pilot can see immediately see if there are any NOTAMS, TFR's, NO FLY ZONES, or any flight restriction in that precise airspace even before they submit their flight plan to the FAA. I use this system even if I am going to be flying in "Class G" airspace just as backup in case any LEO comes up to me and says that my flight is against the law! You know for a fact that your flight plan has been sanctioned and approved by the FAA. There are so many state and local governments that are enacting "Anti-DRONE" laws that the FAA simply cannot keep up with them. Most of these state and local government sUAS regulations are completely unlawful if those regulations are not consistent with the FAA regulations. https://www.faa.gov/uas/resources/uas_regulations_policy/media/UAS_Fact_Sheet_Final.pdf The LAANC informs the sUAS pilot who has requested to fly in restricted airspace, the precise procedure to follow in order to have permission to fly in that airspace. The sUAS pilot will receive contact information for all local airport(s) or helipad(s) that are in the requested flight plan. If you are in Class G airspace then the FAA will approve your flight plan within 60 seconds! For me, this is a great comfort to know that the FAA sanctioned my flight by approving my flight plan prior to the flight.
How does it work?
@CanyonRunVideos
Come on dude! The suspense is killing us. What happened with the court case on the 8/2 ?
Did we win or lose?
@CanyonRunVideos Helloooo? Is this thing on?
@CanyonRunVideos
Did we win or lose?
He sure got awfully quiet... I'm guessing, "contempt of court."...? We may hear from him after his release.Odds are a WIN would have been broadcast from the rooftops IMHO.
1. LAANC is not yet available in all areas.
2. Having airspace authorization through LAANC (or through anything else) still doesn't give you permission to take off and land from properties where it is prohibited such as state parks in some states and National Park Serivce properties.
3. Airspace authorization does not mean that the FAA has "sanctioned" your flight.
I'm guessing you are posing that question about yourself so ...Slow learner huh?
So if I'm interpreting this correctly - all of those state and city parks that have been "locally" designated as no-drone-zones, are in fact open to drones, unless otherwise designated directly by the FAA...?
