WebODM is free open source software. This model was built using 130 jpegs and 1 hour of processing time. Its easy to install by following the instructions. I will post an install video shortly.
Thanks. Any tips for tower inspections would be appreciated.Good instruction JAMBCA, I’m a big fan of WebODM.
Regards
Can’t help you there, I’m a quarry man.Thanks. Any tips for tower inspections would be appreciated.
Just curious, did you ever post that install video? I'm trying out a few different software options and I keep seeing good things about Web ODM. However the videos I see on the install seem to require a few other programs (docker, Git, etc.) to be installed.Its easy to install by following the instructions. I will post an install video shortly.
I did not as they were several other install videos. Its actually super easy to install, just follow their step by step instructions. 90% of it is just waiting around for each step to install.Just curious, did you ever post that install video? I'm trying out a few different software options and I keep seeing good things about Web ODM. However the videos I see on the install seem to require a few other programs (docker, Git, etc.) to be installed.
I gave up on WebODM for several reasons and went with MetaShape.I paid to use the install package and it was super easy. So, I used Dronelink to fly the map area and shoot the pictures. Uploaded to WEBODM and created the map. I am trying to figure out is there a simple way to share the map, 3D Model so clients can see it that don’t have the software? How did you make a video with the 3D model? I know that Maps Made Easy has a simple option to create a web link. So far everything I have seen with WEBODM is rather complex. If you have any recommendations or tutorials you can point me to, that would be great!
