SteelFlyer
- Joined
- Jan 17, 2017
- Messages
- 339
- Reactions
- 205
- Age
- 61
Yes, I downgraded from .500 to .400 successfully and Autopilot works fine.
Same here. Works fine on .0400
What is this process of rolling it back?Yes, I downgraded from .500 to .400 successfully and Autopilot works fine.
I have exactly the same problem , tested with using both my iPhone 6+ and my iPad Air, same result. Created a new waypoint mission and in all attempts I had the same error with the app suddenly crushing and shutting downLooking for comments from Autopilot Users (latest iOS version) with Mavic Pro. I recently downloaded and began using the software and while I've had success taking Pano's, every single Waypoint mission I've tried has failed on me leaving me with little confidence with the expensive app. I created a shorter easier mission to test today and this also failed, with an app crash (iPhone 6) as well.
My experience in each case:
Drone was not far...visual line of sight
In each case The app informed me that Telemetry was lost and then the aircraft disconnected, and I lost connection to the drone with the app and was forced to initial RTH via the hardware button.
The video feeds were very jumpy and glitchy, not smooth at all as they appear in every YouTube video I've watched.
The speed of the Mavic was sluggish and did not match the programmed speed.
The Mavic would also hover for an extended time at the first or second Waypoint and this was not part of the programmed flight plan.
Initiating return to home worked but aircraft positioning for home was way off.
This is now the 5th time I have tried a Waypoint mission and as an engineer I don't find the setup difficult, it's not rocket science. Trying to determine if this is a common/known issue or what I could possible be doing to cause a loss of telemetry and connection. It makes no sense.
Yes , I have today experienced exactly the same issues . Had a waypoint mission that the day before worked fine, but yesterday and today no chance to have the whole mission executed . The Autopilot app simply crashed and shut down suddenly leaving the drone Hovering somewhere along the path. RTH luckily brought it home. I tested both my iPhone 6+ and my Airpad, and also deleted and re-installed the app, unfortunately without any success on the problem describedAnyone? No others have experienced issues? Scratching my head after reading successful mission experiences. Lost telemetry again yesterday at an altitude of 150ft and right in front of me. Seems quiet odd.
