Vision Sensor Calibration issues
Ah, ha...,.I definitely found the problem. It was the screen resolution. I had it set too high. The only problem now is the micro USB cord is too short to keep it away from the monitor on the calibration procedure. Just ordered a new one from Amazon that is three feet long. The one that comes with the Mavic is way too short. After that is should be able to cal.
Any micro USB cable should work. Good luck. Keep us posted
1600x900 is the screen resolution I set to get the black dots to show up on my iMac. The default setting is to high. Not just any USB micro as it has to be at least 3 ft long to get the Mavic far enough away from the monitor to cal it. The short USB cable that came in the Fly More combo is too short.
SK farming
