Welcome from N. California
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello from the Crossroads of America FairOaksDave.
If you haven't done it yet, swing by and take the TRUST test and keep a copy with you when you fly.
It's a free, no fail test that's easy to take.
Although the mini 3 pro doesn't need to be registered with the FAA, but if you add accessories, it may push it past the 249 g limit and will have to be registered with the FAA.
It's only five bucks and the numbers look cool.
Good luck and welcome to the Forum. :cool:
New to flying drones and this community, but eager to get more involved. I'm a Northern California photographer beginning to extend my skills to video and drone video/photography. Just picked up a Mini 3 Pro and have a few days of test flights under my belt.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
I can see that one of our member, MA2 317, has already briefed you on the "where-to's and What For's", so I'll leave the legal stuff to you…, However, If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you are a New-bie, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Welcome to the forum. We look forward to your participation and your view of the world.
New to flying drones and this community, but eager to get more involved. I'm a Northern California photographer beginning to extend my skills to video and drone video/photography. Just picked up a Mini 3 Pro and have a few days of test flights under my belt. Excited to see where this goes.
Welcome to the forum, I’m a photographer/droner in Natomas. We have a lot of controlled airspace around us. You have McClellan and Mather. The airspace apps are really important, B4UFLY is a good one. Aloft has good environmental info as does Airdata. Have fun.
dominicus15
