10% Battery Auto Land
Mimas
UK
Hi guys,
Wasn't sure exactly where to post this and I'm sure its been asked before:
Had a few flights now with this one, and 1 thing thats annoyed me today, i was flying my drone just around the house (outside!) front to back and at 10% battery it went into auto land mode. I had no cancel button, now 10% battery when the drone is still in the near vicinity of you is still a fair few minutes fly time.
Is there any way you can turn this off, i see the mavic mini can be flown right to 0% although not recommended ofc. I would just be rather be in control as basically it seems you have 90% of running battery.
Any help would be appreciated.
Cheers
I think ive just discovered the answer from a YT video, it seems currently in the MA2 you cannot adjust the battery warning levels that you can do in some other models.
Hopefully as its just a software thing this could come in a later update!
Cheers
Those settings just determine when those warnings appear in DJI GO. They do not determine when the drone will auto land.
10% is not good for your batts 20% is the most you should fly to then land and put a freash one in.
Reactions: rmazzaro
Autoland is the safety feature built into the drone.
As others mentioned, flying it at 10% even just around the house is not very good. You should not run the batteries that low.
Can modify the parameters with drone hack software ? I saw a video to turn auto landing off... ( MAVIC MINI )
( Sorry language is Cantonese )
I think is also can work at MAVIC AIR
Freakazoid
