Forced landing
these are some screen shots
I can't get that phantomhelp report to open from here and the screenshhots aren't what's important.
But if you can click on the Download CSV link under the map window and upload the CSV file (or the zip file that contains it) to Google Drive or similar and post a link to that, it would help.
There are two instances where the reported battery percentage drops instantaneously to 0, zero then recovers.
The first starts at 284 seconds, the second instance runs from 981 seconds to 993 seconds, both are followed by battery communcation error messages. I suspect that either the battery wasn't properly seated or perhaps there was something interfering with the connection, I suggest you clean the battery contact and their mates in the drone with isopropyl alchohol.
  • Love
Reactions: RodPad
The link below your post seems to work
Could it be a bad battery(only charged 13 times or so)
I would certainly keep it very low and very close for the next few flights ....... just in case.
I think you are very lucky to still have the drone.
At the first "0" it was over the lake.
For some reason your link is not showing a flight track but the following does
Reactions: RodPad
First of all how did you get the link to work? Everybody said it does not work and I tried every thing. Would not upload csv files or text files
Interesting attachment
I flew the drone last night on a different battery around the same area downtown and it worked fine right to 28% battery
Reactions: RodPad
Your screen shots include the page's URL. I saved one, cropped it to just the URL then uploaded the image to an image to text converter. That got me the URL as text. That text got me to the original page.
The plot comes from CsvView. Which can process the CVS down loaded from phantom help.
Thinking about your drone, I suggest you upload 9 or perhaps 8 other recent flights to phantom help and download their CSVs. Then either process those CSVs with CsvView or look at the right most columns of those CSVs and, respectively, look for quirks in the battery percentages or battery communication errors noted in the CSVs. It might not be the battery at fault.
The problem with phantom help is that in order to be fair you are only permitted to upload 10 or so logs per 48 hours.
I suppose you could try airdata but i think you'd have to scan the CSVs by eye, or, on the airdata website, look at the notification tab of each flight.
Reactions: RodPad
@Yorkshire_Pud Thumbswayup
When I logged on I was thinking how you did that, sure as $hit
You need a pay raise. :)Thumbswayup👌
@Kelowna Drone World, why nobody get it to work because you never shared url. York had to zoom in on the screen shot to find it.
This what you needed to post.
"https://" "www.phantomhelp.com/LogViewer/202408170N0QVD75WYTFPIHPHVHUYXCJ3S487B6E"
To share this.
Anyways you got the info you were looking for and now you know how to get it. Thumbswayup👌
Rod ..
  • Haha
Reactions: Yorkshire_Pud
The problem may be on the battery or on the drone.... can't tell for sure.
the best way is to use other batteries to fly again to see if the problem can be reconstructed...... but may need to fly several times before a conclusion can be made.
anyway, I would never use that same battery again except for testing purpose.
p.s. if you download and view the csv file of the flight log, you can find that there were 4 instances where the current and voltage was "0" during the flight. so, you bet it isn't a one-off incident.
keem21
