200 feet Max Altitude Reached?
dsd317
I haven't flown in a while so I'm not sure what has changed. In the exact same locations as before, I used to be able to fly over 200 feet altitude with authorizations to fly up to 400 feet. Now, I cannot fly over 200 feet. App keeps telling "Max altitude reached"...or something like that. In my app max altitude is set to 400 feet as well. Any idea what's going on?
Are you possibly near an "altitude zone", for example the extended zones coming off runways of a nearby airport?
Check DJI's Geomap which should show these areas:
if you can check you limits in your area: They have made a lot of changes ;
Phantomrain.org
Gear to fly your Mavic in the Rain and Land on Water.
Yes...I think that's it. According to DJI's Geomap, I was in an "altitude zone". Funny thing is that I've flown there in the past (less than a year ago) and was able to fly to 400 feet (many different times). The other thing was that today, I also received LAANC approval to fly up to 400ft.
Here is another view you can get : Its interesting that some of the air restrictions go over the water.
Reactions: dsd317
This is a great link for a quick look into what is happening in the air: Just zoom in and the Magic happens.
ArcGIS Web Application
Phantomrain.org
Gear to fly your drone in and out of the Storm.
Your link to the FAA's UAS Facility Map, which is useful for finding out where you can obtain airspace authorization. However DJI sometimes has their own altitude zones that don't exactly correspond with controlled airspace. Even if you are "legal" to fly with the FAA, DJI's "FlySafe" geofencing can prevent (or restrict) you from flying in an area that DJI has decided is a risk to aviation safety, such as certain heights near airport approach/departure paths. As far as I know, its difficult or impossible to get those types of zones unlocked from DJI (outside of certain enterprise-level or public safety users).
Reactions: dsd317
Exactly in my case. FAA's map shows my location at 400 feet limit, yet DJI's shows same location at 60 meters (196.85 feet) limit.
Reactions: dawgpilot
DJI used to fit their zones more closely with the facilities map. It wouldn't be so bad if you could self-unlock an altitude zone.
I suggest contacting them about the discrepancy.
If you have LANNC authorization to fly up to 400', two things come to mind. First check the max altitude you have selected. Second, you may have to disable the max altitude permission set by DJI.
Phly858
